PCMark 8 Video Editing
Video Editing V2 Part 2 (Creative 3.0 test suite)
This workload uses
FFmpeg to apply video enhancement filters to a high bitrate H.264 video and then encode it to a format suitable for distribution. The FFmpeg binary used is custom-built by Futuremark using a development version of the source available from the project's code repository. The test applies a deshaking filter to a source video at 3,840 x 2160 (4K UHD) before scaling down and outputting at 1,920 x 1,080 (1080p).
DinoPC Troodon
Scan 3XS Z170 Performance GTK4
PC Specialist Define X1
Overclockers UK Titan Agent 47
Fresh Tech Solutions 6600K Falcon R
PC Specialist Vitrum
Fresh Tech Solutions 1080 Titan PC
Dino PC GSX
Fresh Tech Solutions Ultimate Collection 6700K
Utopia Pandora
Overclockers UK Titan Bayonet
Cyberpower Infinity X55 Pro GT
Overclockers UK Infin8 Nebula
PC Specialist Apollo 703
Intel Core i7-6700K (4GHz/4.8GHz)
Intel Core i7-4790K (4GHz/4.8GHz)
Overclockers UK Titan Wave
Intel Core i7-6950X (3GHz/4.4GHz)
Intel Core i7-5930K (3.5GHz/4.55GHz)
CCL Elite Strix 100
Fierce PC Dragon Ripper
AMD FX-8350 (4GHz/4.6GHz)
200
300
400
500
600
Seconds, lower is better
PCMark 8 Photo Editing V2
This workload involves making a series of adjustments to a set of photographs using
ImageMagik - an open-source image processing library to adjust brightness, contrast, saturation and gamma. When a favourable balance is found, the changes are then applied to the rest of the images in the set. TIFF files up to 67MB in size are used.
Dino PC GSX
DinoPC Troodon
Utopia Pandora
CCL Elite Strix 100
